Is the keyboard built into the top piece along with the touchpad
Is the keyboard built into the whole top piece with touch pad or is it a separate keyboard by itself? I need to replace the keyboard.
この質問は役に立ちましたか?
この質問は役に立ちましたか?
Hi,
Here is a link to the service manual for an Acer E5-571P.
http://www.manualslib.com/manual/440339/...
On p.104 ( http://www.manualslib.com/manual/440339/...) of the manual it shows the removal of the keyboard. It is separate from the palm rest and touchpad.
Here is a link (from the same manual) which gives the part number for the keyboard.
I suggest that you start from p.100 which shows the pre-requisites necessary for removing the keyboard. Also take note of the warning regarding possible damage to the keyboard during the removal process.
Hopefully this is of some help.
このアンサーは役に立ちましたか?
過去 24時間: 1
過去 7 日: 3
過去 30 日: 4
今までの合計 400
