GT-P5113 Samsung Galaxy Tab 2 10.1" Replacement Digitizer
Tablet Model: GT-P5113
The digitizer Cable has the following info:
S295C
Expresso10 GT-P5100KTL
R01 1233
Can someone point me in the direction for a replacement please?
http://www.ebay.com/itm/Samsung-Galaxy-T...
Here is a pretty reliable source on ebay. The new digitizer even comes with adhesive on it so you don't have to worry about that. Also says it is an OEM Samsung part. It is also a pretty good price to. Hope this helps!
A little piece of advise about buying parts on ebay, make sure you read the full description and make sure they have a good return policy. Then test the screen before you seal it down to make sure the part is not defective.
Cheers!
このアンサーは役に立ちましたか?
このアンサーは役に立ちましたか?
This one is totally different than the ribbon cable I have. No numbers or names match at all.
過去 24時間: 1
過去 7 日: 1
過去 30 日: 1
今までの合計 266
