メインコンテンツにスキップ
The aluminum PowerBook G4 was released by Apple to replace the previous titanium-body model. The 12" and 17" versions debutted in January 2003 with the 15" version following in September of that year.
683回答 すべてを表示
some letters on my keyboard are not responding
I installed a new hard drive and when I tried to installed the OS x, some of the letters on the keyboard were not responding. Does $#@&&! to do with the fact that maybe I connected the board incorrectly ?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
2件の回答
ベストアンサー
Sure. Just lift the keyboard and look in the socket (male and female) to see if they're is clean and then reseat it. You don't even need to screw the keyboard in to test it. A little tape helps hold it in place.
このアンサーは役に立ちましたか?
スコア 2
2 件のコメント:
さんによる
I followed steps 1-6 from the ifixit manual on how to install 1.6 ghz hard drive of my powerbook g4 17" again because this was the only time where I manipulated the keyboard. I followed the steps again but only some of the keys work. Neither the delete key works. In your explanation do I need to do it as if I was going to change the keyboard? (I took a look at the manual but it seems I am getting into unscrewing things I did not mess around before. Can you be a little bit more specific of where to find the socket you mentioned? I will really appreciate it.
さんによる
コメントを追加
I find it helps just to remove the battery then put back in again and reboot the computer.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
lmichjones さん、ありがとうございました!
統計データ:
過去 24時間: 2
過去 7 日: 2
過去 30 日: 2
今までの合計 1,353
