メインコンテンツにスキップ
A touchscreen smartphone made by LG released in September 2013 with the model number VS980.
185回答 すべてを表示
Backlight turns off on high brightness
Hi!
Mine LG G2 has a very strange backlight issue. The backlight is working on low brightness levels, but turns off after 40% of brightness. Under very bright light I still can see that the image is still present on the display, so the screen is working itself. When I change brightness level back under 40%, the backlight turns on again.
What could be faulty? Screen or motherboard?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
Did you ever solve the problem?
Was it the original screen?
このアンサーは役に立ちましたか?
スコア 0
4 件のコメント:
The screen was original. The issue has gone after motherboard replacement.
さんによる
Excellent, thanks for the quick response. I've just picked up another g2 with a broken screen (cheaper than buying another mobo).
That's a real weird fault though. Did you contact LG support?
さんによる
My G2 suffers from the exact same, 40% then the backlight goes.
It's useable at 40%, but that's not the point.
さんによる
Simon, the warranty of my phone was over long time ago, therefore I didn't contact support. However I still own that faulty motherboard and it's interesting to know what exactly the reason is.
さんによる
コメントを追加
回答を追加する
Igor Bljahhin さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 3
今までの合計 201
