How do I do a hard reset on my tablet
how do i do a hard reset
この質問は役に立ちましたか?
although I have not done an Envizen tablet most android tablets are the same in there hard resets . first check to see if there happens to be a reset button anywhere on the tablet .
If not,First, turn your tablet off. Then, power the tablet back up by holding down the volume (either + or - ) and power buttons simultaneously. Continue holding the volume button until the screen says "Booting tablet in recovery mode." This will give you a picture of an Android. Tap the android, and you will be given a screen with several options. Move between the options with the + and -, and select with the power button. Go to the option for Factory Data Reset and select it. Scroll down to `the Yes, and then the tablet will erase its memory back to factory settings. Once it has completed, select Reboot Tablet Normally. Remember when you do a factory reset you lose all data and it will be like the day you started it for the first time all apps photos, music, addresses and phone numbers will be gone so back that up before you do this . Hope this helps
このアンサーは役に立ちましたか?
This was easily understood and instruction clear.it saved my day
mine shows a picture of the android guy on his back with a red triangle over his open stomach! what does that mean?
Mark this may help https://www.youtube.com/watch?v=58EPvbwP...
Greetings,
I h ave an Envizon EVT10Q tablet bought from a reputable source on Ebay. have tried several times to factory reset to no avail. Each time I go through the process and try to sign in withe my own Google account, I am asked to use the address originally synced to the tablet . I have tried using drfone to no avail. My PC doesn't want to recognize the tablet either. Please help if you can. Thank youi.
Robert have you tried to wipe the cache partition instead of doing the factory reset. you may need to get a clean boot to get things rolling
過去 24時間: 1
過去 7 日: 3
過去 30 日: 23
今までの合計 15,958
13 件のコメント
how do i do a hard reset on my tablet
john12708 さんによる
My tablet wont turn on even when i leave it to charge for hours what do i do?
Jacob Mendoza さんによる
I have a Envizen tablet,ive already rest it a couple of times and when I turn it on nothing seems to happpen
Sylvia Villalobos さんによる
i bought this tablet from hsn .i tried to reset. its not in english when i try to reboot it thank you
Phyllis さんによる
I tried to do a factory reset on my Envizen tablet. It keeps getting stuck where it says insert sim card it won't let me skip this step .Ive pushed skip several times without it doing anything. Help!
Tom Slavens さんによる
8件以上のコメントを表示
