How to reset bios
How to reset bios password
in laptop the password bios is stored in IC like eeeprom you cant clear it by removing the cmos battery
in your model c50
you will have in motherboard 2 IC with name Winbond 32 and 16
you must pull out the winbond 32 (8pins) with hot air then put it in a programmer
then you must search for bios file with extension bin or rom and programme it into the IC
this is the only way to remove bios password
you need a tech
このアンサーは役に立ちましたか?
removing the mother board battery should help. check youtube for your model
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 4
過去 30 日: 10
今までの合計 3,246
