faint green light will not power on
macbook will not power on and will not charge battery it has a faint green light on power cord
この質問は役に立ちましたか?
この質問は役に立ちましたか?
First inspect that all the pin are extending from the magsafe (use a tooth pick to push them), and that the receptacle is clean and able to make good contact
このアンサーは役に立ちましたか?
Had the same problem. I took apart the macbook and cleaned the magsafe and it started charging with a full green light but another problem came up. Every 2 minutes or so, it constantly asks me if I want to "shut down" the macbook as if I pressed the power button.
このアンサーは役に立ちましたか?
Stephane, to avoid confusion please cut and paste this response into a new question. Thanks
過去 24時間: 0
過去 7 日: 0
過去 30 日: 2
今までの合計 1,319
