メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
2012年3月16日に発売されたiPad Wi-Fi機能搭載の第3世代モデルです。モデル番号はA1416です。修理には温めて、慎重にこじ開ける作業が必須です。
What is the problem
I left the iPad for three months at lower than critical charge. It won't turn on now. Tried charging but did not work. Connects to iTunes. ITunes says iPad in recovery mode. Need to be restored. Downloads the software and does nothing. May be due to pass code. Thought the battery died. Opened it successfuly but battery seems alright.. Can't figure out the exact problem before I buy the parts. Any help will b appreciated... Thanks in advance...
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
Sounds like its in DFU mode. Try holding the power and home button for 10 seconds to do a hard reboot. If this doesnt, work try charging it for a while. Im not sure who long you tried to charge it, but I've had to leave iPads for close to an hour before to get them charged up enough.
このアンサーは役に立ちましたか?
スコア 1
3 件のコメント:
I tried holding the home and lock buttons together... Didn't work.. Left it all night on charging.. Still did not work..
さんによる
Is there a way to test the LCD alone.
さんによる
Not that I know of. Since you opened it, I know you reseated the cables etc. The battery could be bad even though it looks fine. I have also had an iPad 2 in the past that flat out died and nothing I did brought it back. There is a charging IC chip of some sort that can go bad, but I dont do board level repairs, so I didnt pursue that troubleshooting step.
さんによる
コメントを追加
回答を追加する
Ashish さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 3
過去 30 日: 6
今までの合計 108
