Why is my phone not turning on?
My phone will not turn on or charge when plugged in it does nothing at all.
While plugged into the charger hold down power/volume up and down buttons for 10 sec. See if this works. If not take to local carrier to try a new battery.
このアンサーは役に立ちましたか?
Works perfect, Thought I was going to have to get another phone. Thank you!!
Hello, Since Th G3 model LG has had a bad issue with the phone bricking itself. THIS IS NOT A BATTERY ISSUE. Im a Technician Here in California. http://www.lg.com/common to contact them about issues. this also is the same with the LG G3,G4, and V10 boot loop issues.
このアンサーは役に立ちましたか?
i have boot issues with my lg v10 , do you know if there is any way to fix it because my phone is out of warranty
My LG V10 just went off. And it's can't turn on again.
To answer Diego's question, if the issue is the common boot-loop issue, then fixing it requires some level of skill, as the solution to the problem is reflowing the solder on the SoC or, if you have the skill and supplies required, reballing the SoC. To prevent the problem resurfacing, replace the stock thermal pad with a high quality thermal pad or paste, since the stock one doesn't do a good enough job of transferring heat from the SoC
Keep an eye on this lawsuit.
このアンサーは役に立ちましたか?
i also face this problum...
i've visited most of the best repairer but most of them tel me that it is an compney eror..
one of them repair my fone as wel.. my sel was start working but only for one day...
this problum could never be solved...
このアンサーは役に立ちましたか?
From what I gather, the LG models after the G3 have had an issue with the capacitors not being able to sustain a charge after some months of use. This may be a result in letting the phone die over and over again. Once it boot loops once, or won't power on, give up on it. Take it to LG within the 1st year of purchase (if applicable). If you bought it more than a year ago without insurance, you're out of luck.
このアンサーは役に立ちましたか?
No, the problem with the V10 is that the CPU overheats and cracks the solder balls on the SoC
Source: personal experience involving multiple hours of online research and a semi-successful repair (did a reflow, but didn't heat the solder long enough so I ended up with a cold joint, redoing it after work today)
it will charge but will not turn on
このアンサーは役に立ちましたか?
Yes,it will charge but it won't turn on.
Lg phones are not suitable for routine use.
LG V10 no open mobile
このアンサーは役に立ちましたか?
LG mobile not good
LG company not good
LG V10 not open mobile
Is this “press and hold volume and power for 10 seconds” solution for OLDER model V10s?
I have two LG v10 phones, and this solution doesn’t work on either one.
(One phone won’t turn on—the other is frozen on the logo screen! Talk about a one-two punch!)
このアンサーは役に立ちましたか?
過去 24時間: 1
過去 7 日: 5
過去 30 日: 24
今までの合計 26,504
2 件のコメント
Charge your mobile battery with Universal Mobile Cell Phone Battery Charger. Then restart your phone. http://www.vidmateappsforpc.com/
Henry Anderson さんによる
I have tried charging the battery with universal charger and I even bought a new battery but still not turning on
Mark Asante さんによる
