When was this mower made Murray model # 40702x92c?
When was a Murray riding lawn mower made, Model # 40702x92c
It has a tag under the above model # that says date of manuf. 3063.
It must be coded #. I know its not made in 1963.
この質問は役に立ちましたか?
この質問は役に立ちましたか?
bobthomas1944 you are probably right when you say that it was not build in 1963. But it could have been build the 63 day of 1973.
Murray used a couple different ways of how the date of manufacture was list.
1970's tag format YDDD
1980 and early 1990 tag format DDDY
Late 1990 and Early 2000 tag format YYDDD
Early 2000 on MM/DD/YYYY
Your model number 40702x92c tells us that it has a 40 inch deck was, actual model is 702 and was build for X92C which could be anyone from Walmart to homedepot. Basically it is who it was build for.
You may have better luck by checking the tag or stamping on the engine. Let us know what you find.
このアンサーは役に立ちましたか?
I believe it is a julian date. So 3063 is 2003 (the first digit is the year) and 063, the 63rd day of 2003 would be March 4th
このアンサーは役に立ちましたか?
So then if mine says 2733 when was mine built
過去 24時間: 2
過去 7 日: 13
過去 30 日: 39
今までの合計 6,748
