メインコンテンツにスキップ
2013年9月10日に発表されたApple iPhone 5cの修理情報とガイドです。モデル A1532, A1456
1233回答 すべてを表示
iPhone 5C Apple logo flashing? HELP
Hello, When I put the charger on my iPhone the apple logo flashes and when I disconnect charger the logo stop flashing and iPhone wont turn on. I tried to hold the home button and lock screen button the iTunes logo appears but when i disconnect the charger to plug to laptop for restoring through iTunes the phone goes off again. I can repair phone by myself just i cant figure out the problem. Please help me!!
Update (09/08/2016)
I think it might need to replace the battery, cause I putted phone for charging for about 2 - 3 hours but later I disassembled it and reassembled it to make sure everything was on right place and connected well and when I turned my iPhone it displayed the symbol of not battery.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
3件の回答
最も参考になった回答
It sounds like you have a bad power IC chip that needs to be replaced. For me, it's not an easy repair because it involves soldering. However, there are services you can purchase on eBay that do this for around 40 bucks. That's definitely worth it and I have had this done for customers in the past.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
Hi. If you have tried restoring it (and that has not worked) try entering your phone into DFU Mode (simply Google "DFU Mode Apple" and follow the instructions). This will totally reset your phone, erasing all of your data. It will also remove the software and reinstall it. If this does not work, you can try contacting Apple for further support.
このアンサーは役に立ちましたか?
スコア 0
2 件のコメント:
I tried it, but it says error 2009, I tried some tutorial to fix it but It doesn't work. It was working 1 month ago, but than i brought a digitizer and it was faulty I had to return which took 1 month and after that when I got a new one, that's when It made that problem.
さんによる
Beyond that, I don't know. Somethings may have occurred to the iPhone whilst the digitalizer was replaced. Or it may be that the error was caused by your iTunes on the computer. If it's not updated to the latest version, update and try again.
さんによる
コメントを追加
I fixed it, it was the battery, I ordered a new one and it is working fine now
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Mirza Zaheer さん、ありがとうございました!
統計データ:
過去 24時間: 2
過去 7 日: 3
過去 30 日: 6
今までの合計 6,189
