メインコンテンツにスキップ
An easy to use home Espresso machine created by Saeco and rebranded for Starbucks. This machine is excellent for every day espresso drinkers and has an excellent build and product life.
140回答 すべてを表示
Pump to the portafilter
Is there a way to adjust the amount of water that pumps out of the portafilter? When I try to pull shots, the water seems to some out too fast or in large amounts. It may be my tampering but I've tried tampering different ways and the water seems too powerful.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
The pump will keep running until you turn off the pump button, so if you want a smaller beverage just turn it off sooner. If the coffee is dispensing too quickly even though you're tamping firmly, you probably need to grind it finer and/or make sure the basket is completely full, settled and leveled off before tamping. There is no way to adjust the water pressure on the machine.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
je2na4eva さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 1
今までの合計 102
