OBC vs charger problems
Have a 1995 club car, need to figure out if charger, batteries, or OBC is bad. Have rebuilt charger with kit because 15 amp fuse on front kept blowing. Now nothing charging.
@bigdave00 for now I'd suggest that you follow the troubleshooting flowchart from the manual:
Let us know what you find so we can assist you further
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 1
過去 30 日: 5
今までの合計 1,183
@bigdave00 I assume that this is the electric version of the Club Car. did you check the output of your charger after you rebuild it? Why did you have to rebuild it? The 15A fuse is the one on the charger or the one on the cart? What do you refer to as the OBC (on-board computer)? you checked the voltage on the charger receptacle? Is your cart a V-glide (36V) or Powerdrive (48V) model?
oldturkey03 さんによる
