メインコンテンツにスキップ
Meizu社によって製造された修理ガイドならびに製品サポート
36回答 すべてを表示
Antenna tabs broken, need hardware repair suggestion
Hi, during a dissasemble of a meizu m2 note sadly i cracked and broken two antenna tab in the the usb chargin port pcb.
So i insert the sim card and i noticed there is a X so i'm unable to connect mobile data. I already saw the possible replace (luckly is not the whole motherboard) but is divide in two part on Ebay.
So my question is: the mobile data problem could be the issues for faulty antenna tabs? Please help me i need an opinion as fast as possible.
http://imgur.com/a/BDsyk
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
Hi to everyone, i would like to update my question and how i fixed the issues, so i fixed the issues by replacing the usb connector board (bought on a famous auction site) and after that you have to (sadly) re-assemble the complete case in order to your mobile network work fine.
The latest step is really important because in the backcase (inside) there are the antenna's flex's (the white one) otherwise you are unable to get any mobile data, so is not like the other smartphones. Hope this will help someone.
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
Thank you so much for helping me in this question. I have the same problem and with your help I will try to fix it. Thank you, thank you...
さんによる
コメントを追加
回答を追加する
Vermillion さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 694
