blu life one x not charging
blu life one x has stopped charging...tried charging from a laptop, have tried multable charging cables...what should i do next?
Sent mine back to the shop, battery would show a percentage ie: 16% regardless if charged or not, and would never change untess unplugged, plugged back in, then it would show ie: 100% and never change... ...Sent it back with phone back cover (minus the battery and sdcard) they sent Me a new one the battery charged discharged just fine, and displayed properly... All was ok then...
このアンサーは役に立ちましたか?
how do you contact their uk support centres - I bought mine from amazon uk?
このアンサーは役に立ちましたか?
The daughter board for charging is easily replaceable if it's damaged. The battery itself is glued on, but if it's bad you can easily pry it off and throw it away once it's discharged, replacements should be available on ebay.
このアンサーは役に立ちましたか?
My Blu life one x2 is not taking a charge and I don't know what to do.
Do I need a new phone?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 3
今までの合計 3,326
1件のコメント
I can't find a battery replacement for this phone,; not longer available for this model so I can't recommend it. I had to buy a new phone, (Motorola).
Shelly Morgan さんによる
