メインコンテンツにスキップ
The Microsoft Lumia 535 is a Windows Mobile smartphone developed by Microsoft Mobile. It includes a 5-inch display and a 5-megapixel front-facing camera.
27回答 すべてを表示
Why gps find vey late
My phone gps is not work well. It find very very very late.
I use lumia 535 about 1year. It have very very very very bad location and gps system. It find location very very very very late, Sometimes about half hour. What is the solution if there is?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
Try this : first of all install Hardware tests from the Store.
1. Shut down your phone and remove the SIM and restart it (in this way the phone can't get the position from the GSM-3G network)
2. Disable the WiFi (the phone can't get the position from the Wi-Fi network)
3. Open Hardware tests, go outdoor or near a window with your phone and start the Gps test.
4. Wait a little bit and you will get your position. The last line of the Gps test screen must say Position source : Satellite.
5. Now open Maps or Here drive+ to check if also the apps can get the right position.
6. If all went right you can reinsert your Sim and use the phone as usual.
Good luck.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
sanane さん、ありがとうございました!
統計データ:
過去 24時間: 2
過去 7 日: 5
過去 30 日: 8
今までの合計 425
