My PS 3 will not play games
I just bought a PS 3, tested it out with a DVD but it will not read games, what is the problem?!
この質問は役に立ちましたか?
この質問は役に立ちましたか?
@ary14 you are not telling us what it does. From your short description I take it that your optical drive does not read any disk, Possibilities are your laser is either dirty or has failed. You could try a commercially available lens clean, i.e. Maxell makes a brushless / dry Blue-Ray/HD-DVD cleaner. Or you could try this. If none of that works, consider changing the laser assembly or the drive itself. Remember that you must replace the board on the new drive with the one from your old drive since they are paired with your console. Let us know if that is the issue with your PS3 or if there are any other issues.
ガイド
難易度:
中レベル
15 minutes - 1 hour
ガイド
難易度:
中レベル
20 minutes
このアンサーは役に立ちましたか?
It is a new system, bought it a couple of days ago. I watched Tyrannt on it but when I tried playing a game on it, it will just roll and click but will never pick!
It does sound like a bad drive...
過去 24時間: 1
過去 7 日: 1
過去 30 日: 6
今までの合計 112
1件のコメント
hilary obiorah さんによる
