メインコンテンツにスキップ
2013年9月10日に発表されたApple iPhone 5cの修理情報とガイドです。モデル A1532, A1456
1233回答 すべてを表示
iPhone not working after rear box replacement
Help! My iPhone does not turn on after replacement of rear box . There is no sign of operation . The problem may be the battery? I folded and forced when try remove it. thanks
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
6 件のコメント:
Wait why did you try to remove the battery? It's not required for replacing the front panel.
さんによる
Sorry, I forgot to mention that also replaces the rear box.
さんによる
Actually, I couldn't disagree more with that. Disconnecting the battery should be the first in any repair of an electronics device. You should never be connecting or disconnecting components from a board with power to it, powered on or not.
Now, are you sure the phone isn't powering on? It's possible that it is powering up but you don't realize it because the LCD is either bad or not properly connected. Try plugging the phone into a computer and see if it recognizes it. Or try changing the ringer to vibrate with the switch on the side and see if it vibrates, then post back
さんによる
Did you put the screws all in the correct screw holes especially the 4 screws that go on the 3 front panel ribbon connector metal cover?
If the a longer screw went in the screw holes that sit on the logic board then you have damaged the circuit for the display on the logic board most likely.
さんによる
Hello , I checked the screws and it seems to me are correct .
I also tried connecting it to the PC , still no sign of life ...
On the issue of the folded battery, this can not damage it ?
Another question . Can I have damaged the logic board ?
Thanks
さんによる
1以上のコメントを表示
コメントを追加
1 件の回答
it doesnt sound like long screw to me though because he says he's not getting display at all. In my experience, long screw damage usually presents as a bootloop or red/blue screen. I'm not saying it couldn't happen, just that I've never seen it
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
Can you imagine anything I may have done wrong ?
The logic board can be easily damaged ?
Thanks
さんによる
コメントを追加
回答を追加する
leocardosoex さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 66
