The Nerf Dart Tag Swarmfire was released by Hasbro in 2011.
sania Ahmed @sania
評価: 76
5
投稿日: 2016年7月29日
Can I manually fire the Nerf Dart Tag Swarmfire with the device not turned on?
この質問は役に立ちましたか?
Ashely Janae Wodall @pass901
評価: 242
9
2
The power switch is found on the top of the Nerf gun near the stock end. The only way to use the Nerf gun is to turn the switch into the "on" position, it does not have a manual firing feature.
このアンサーは役に立ちましたか?
Bily Bob @bilybob
評価: 1
投稿日: 2021年4月7日
You could if you found a way to put some sort of hand crank on it
過去 24時間: 0
過去 7 日: 5
過去 30 日: 6
今までの合計 182
