メインコンテンツにスキップ
Repair guides and support for wired or wireless devices that provide internet connectivity.
How to disassemble the Asus RT-AC55UHP router?
So i have this router for a few moths, but after a prolonged use like going on GTA online or other network intensive applications for a few hours. The connection started get unstable like dropping wifi connections. Sure something went wrong inside the router . I try to tear it down and apply a few heatsinks. After unscrewing the four screws under the bottom I use a card to loosen the clips, yes this works for the front clips, but the clips that are at the back of the router, the left and right side still get stuck. I checked out for lot of tutorials that for similar models. None of them work. So anyone can tell me how to loosen these clips in a nice and safe way? I tried to figuring it for hours!
P.s.: the router's warrenty has already expried.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
1件のコメント:
Have you done latest firmware update?
さんによる
コメントを追加
2件の回答
Use a 'plastic opening tool' that you can buy a set of online. They come in various sizes and shapes, some resemble a thick guitar pick and some resemble a sharpened chopstick at one end and the other end resembles a screwdriver's tip. They are useful for opening laptops, routers, hubs, etc. without damage.
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
Also old plastic cards like credit cards, etc. work well.
さんによる
コメントを追加
If you're still looking for this, the answer is: insert anything to entry point, pry the bottom outwards.
There are 1 huge and strong clip on both left and right (position: center), and 3 clips on the front and back (position: left, center, right). The clips on the center of each side is 15mm wide. I recommend you to insert a pry tool (metal ok, not weak/floppy), slide it till you hit the clips, then pry the bottom part outwards.
For the back one, I flexed mine, but little by little and pry the entry points
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Chung Him Kwan さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 5
過去 30 日: 19
今までの合計 638
