メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
2014年9月9日に発表されたこのデバイスはAppleが進出した最初の身につけるスマートデバイスです。iFixitの修理マニュアルではApple Watch (スティール製)とApple Watch Sport (アルミニウム)どちらも対応しています。
Replaced digitizer not recognizing touch
I recently replaced the digitizer on my Apple Watch but I did not replace the LCD. I followed multiple guides to make sure every thing was going correctly. I ordered one digitizer/glass unit from Amazon and it did not work. I figured it was defective so I ordered one from iFixit, who I trusted more. It did not recognize my touch either. The only thing I didn't do was apply LOCA glue because it wasn't needed as far as I was concerned. Any help with this issue?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 2
コメントを追加
2件の回答
最も参考になった回答
I repaired an apple watch myself, but I used a full digitizer/LCD unit.
Although you probably tried this already, when I firstly reassembled my apple watch, touch wasn't working either, but only because the connector wasn't connected properly, although I was convinced I had it connected correctly. Maybe checking this could help you out.
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
@klausibert which was the connector which was not connected properly? The one linking on the top left of the watch from which the display ribbon cables start?
さんによる
コメントを追加
I have the same issue and ordered a new digitizer to replace it, Did you ever find a fix? Apple wants to charge $200
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Ethan Turner さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 4
過去 30 日: 9
今までの合計 251
