Why my iPod not charging
Yesterday i tried to put the USB electrician on my iPod charging port and it pop up " The accessory may not be supported" and now its not charging? what can i do. Now its drained. What can i do please help me.
Did the charger come with the package? If so, i dont know what to do.
Get a proper charger
このアンサーは役に立ちましたか?
Clean ur charging port with a tooth pick. It works I had to do this on my iPhone!
このアンサーは役に立ちましたか?
Its clean. But its not working. Do you have idea what can i do?
Does it make the charging sound when plugged in? If not then it's not clogged but jammed with lint! I litterly had to scoop out the lint which I could not see with a tooth pick all the way in the back not the sides.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 4
今までの合計 724
I think the charging port is clean. When the message pop up "The accessory may not be supported" it stop working. and i turn off the iPod. It still wont charge. and then i click the home and power off button at the same time and it still doesn't work. Do you have more ideas what can i do to my iPod?
oscarjosephdamalerio さんによる
