メインコンテンツにスキップ
Asus ZenFone 2 (ZE551ML) is an Android smartphone manufactured by ASUS released March 2015.
Camera failed to launch
I am getting this error on my zenfone 2, is there anyway to know if this is due to a hardware problem or a software problem? Any place where i can buy the camera replacement?
My country doesn't have Asus service
Actualización (25/07/16)
I have disarmed and note that the front camera was incorrectly connected , connect it again but the error persists, something I can try?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 5
コメントを追加
9件の回答
最も参考になった回答
you can use the calculator test benchmark for see if is a hardware problem.
open the asus calculator and insert .12345+=
このアンサーは役に立ちましたか?
スコア 4
2 件のコメント:
It says Something wrong with Main Camera Capture Test!
is it hardware right¿
さんによる
looks like, I have same problem.
also front camera is not working or only back camera ?
さんによる
コメントを追加
Sir , I did so (.12345+=) . Flash is working & showing test passed but cemara showing black ..
Kindly advise me to solve the back cemara problem
Prasad , Hyderabad
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
everytime i test the camera features the SMMI TEST shuts down. I have problem with the camera not working since last week. Everytime I try to open the camera, it shuts down by itself and tells me to restart the cellphone and when I do it the problem persists. Can anyone help me with this problem? Thank you.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Try doing a battery pull..
  1. Turn off the phone.
  2. Remove the battery.
  3. Wait about 5 to 10 minutes.
  4. Put back the battery.
  5. Turn the phone on.
Hope this helps.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
I got the same priblem now and im browsing the answer how can i fix it.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
my phone was dropped and i found out 1 of the small component was missing, soldered the missing component as a joint (make it short jumper) after that camera starts working.
just look carefully at all the components should be something loose or missing …
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Hi. I have the same problem and same situation (my country does not have an Asus support centre). All I can tell you for now is that buying a new camera will not solve the issue. i found one at a good price on AliExpress and had it shipped. Waited for the longest time for it to get here, only to find out that the issue is not with the camera itself, but with the logic card. And having no support centre nearby, fixing the logic card will not be happening anytime soon.
Sorry to be the bearer of bad news.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Asus have fixed the problem by ota update on October 26th
You just fallow the link to update your camera into a next level
https://youtu.be/UOYooxdVwBQ
Follow the
https://g.co/payinvite/a9cy00
このアンサーは役に立ちましたか?
スコア 0
2 件のコメント:
Follow the link for info of Asus camera problem
You can mail me on ghosh.sumanfot001@gmail.com
さんによる
All camera problem will solve
See that tutorial video
さんによる
コメントを追加
This is what worked for me. I have no idea what steps are essential.
The camera on my zenfone was dead. Every diagnostic said it was dead.
I did a factory reboot. The camera was still dead.
A couple weeks later, I rebooted the phone. I laid the phone flat on a surface so that the lens would only see dark.
I fired up the camera app. Let it sit for a minute. Went from the rear-facing to the front-facing setting a couple times. I picked the camera up, and for a few days it has been working fine.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Kinzo Edge さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 19,466
