pink dot on screen after fell into water bowl
my friend's phone fell in a water bowl for 3 seconds and it has a little small pink dot , i want to know is it fixable or should she order another phone? thanks for helping me !
この質問は役に立ちましたか?
この質問は役に立ちましたか?
In answer to your question, yes, it is fixable. But as @oldturkey03 pointed out your friend should stop using the device until it is properly fixed.
Water damage is fickle in that it can seem fine initially, but then give you some unexpected curveballs in the near future. For the best possible outcome and the longevity of the device you should clean it properly in an ispopropyl alcohol solution and clean any signs of corrosion, along with replacing the battery. The pink dot, depending on the location (like on the LCD), may not go away until/unless the screen is replaced. With these devices, that can get quite expensive.
To summarise:
If you feel like this is out of your capabilities just take it to a local shop and ask them to do a repair on it!
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 69
1件のコメント
@kaye what have you done to fix the water damage? the more you mess with the phone, like turning it on etc. the more likely you are to shorten out the logic board. At least remove the battery for now. STOP USING IT
oldturkey03 さんによる
