How to fix WiFi
The WiFi. when u connet to it won't connect jt just keeps saying saved on jt tryied reseting it and everything i knkw the wifi ks open cause i connect threw jt on my phone
In smartphones you have to go your Wi-Fi settings and make sure Wi-Fi is enabled and that you are connected to the proper service set identifier using the correct security password. Make sure airplane mode is disabled and that your time and date are correct. For Windows , make sure the Wi-Fi switch is turned on, and that the device is not in airplane mode. Right-click on the network icon in your system tray and select troubleshoot problems to run the windows network diagnostic routine. Very often this will correct common issues by resetting the adapter. Also check your phone for a Wi-Fi Button or Switch.
このアンサーは役に立ちましたか?
My viking pro tablet wont let me turn on the Wi-Fi ive tried everything i can think when i go to turn it on it goes to off on its own it wont stay on
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 4
過去 30 日: 7
今までの合計 5,142
