メインコンテンツにスキップ
Repair guides and support for netbooks manufactured by Compaq.
18回答 すべてを表示
My computer Loss the power after 2 min when charger is pluggged
Computer is working fine when it is in on battery, but when I connect my charger my laptop is loss power(off directly) after 2 to 5 minutes.
Already i check my adapter it is OK, with other adapter same problem occur.
Also i check my power supply of my house no problem was there, It is happen in other home also.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
Hello,
probably you will have a bad connection in the laptop. Try to replace the DC jack. or try with an other..
If you know enough about electronics, you can try to measure out the PCB connecting your dc tot the main board. I had a same issue to an older model of acer. it was a bad connection in the PCB.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Anup Pasari さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 60
