メインコンテンツにスキップ
The UE Mini Boom is a very compact Bluetooth speaker that has a built-in rechargeable battery, speakerphone capabilities, a line input, and ruggedized design.
2回答 すべてを表示
Speaker has suddenly stopped connecting to all my devices.
I have connected to my phone, tablet and computer in the past with the UE Mini Boom without any issues, it has now stopped connecting to all devices. I have read that to solve this problem you hold the - volume down with the on/off button until it makes a sound and it should resolve, however my speaker has a slide across on/off button so I"m unable to perform this.
I have also run application to see if there are any updates required which there wasn't.
Cheers
Lynda
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 2
コメントを追加
5件の回答
最も参考になった回答
In case the original poster checks back on this 8 months later, or anyone else has the same problem:
I had the same problem, and was able to hard-reset my UE Mini Boom by switching it on, and holding down the 'Bluetooth' and 'Volume Down' buttons.
After 5–10 seconds the speaker made a sound effect (different from its usual on/off/pairing noises). I then turned off the speaker using the switch at the back, turned it back on, made my iPhone 'forget' the speaker (Settings > Bluetooth > My Devices > UE MINI BOOM > "i" symbol > Forget This Device), and was then able to re-pair it as a new speaker.
このアンサーは役に立ちましたか?
スコア 6
3 件のコメント:
That did the job--Thanks
さんによる
You are a miracle worker!! Saving lives 5 years later. Thank you!!!
さんによる
still works in 2023! thought maybe my 10 yr old UE mini boom was too old to pair with new phones
さんによる
コメントを追加
Hey
I had the same problem and just figured it out. To reset the mini boom you need to hold down the volume down button and the bluetooth button. You should here a crash noise. Then try and repair it to your bluetooth device with other devices bluetooth switched off. I turned my phone to flight mode when pairing the mini boom back to my computer.
Hope this works for you!
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
This is the thing that worked for me!!! Thanks so much!
さんによる
コメントを追加
I have tried as done by some users, it don’t work at all.
このアンサーは役に立ちましたか?
スコア 0
2 件のコメント:
I tried it also, it didn't work for me either
さんによる
Didn’t work for me either I switched on my mini and held the volume down and Bluetooth buttons down for over 10 seconds and it never made a sound currently I only have the red light flashing and a negative sound when I try to turn it on
さんによる
コメントを追加
You have to get the ue mini boom apk file on chrome or Google then go to files download the app and then use the app to connect once again
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Hard reset did the job.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
realmehypno さん、ありがとうございました!
統計データ:
過去 24時間: 3
過去 7 日: 22
過去 30 日: 119
今までの合計 7,179
