iPhone randomly flips between mute and non-mute
My iphone 3gs randomly flips between being muted and being live without touching the switch. Very annoying and I;m missing a lot of calls. Can anyone help?
This is the part you will need to replace.
iPhone 3G/3GS Headphone Jack Assembly
Its usually the actual switch on here that goes bad.
このアンサーは役に立ちましたか?
+ you catch on to giving answers quickly
the ribbon needs to be changed that controls the mute switch, power button, headphone jack, and volume button. It's all connected together.
erika
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 6
過去 30 日: 7
今までの合計 3,112
2 件のコメント
hi i have the same problem..
i just ordered and received the new mute butoon, which parts else do i need for solving this problem, or can i fix it whit juste the new mute button ?
mail さんによる
if you only ordered the external button you may need to order the flex/ribbon as well. it is headphone/volume/mute and power all on the same flex.
pollytintop さんによる
