Where is the camshaft position sensor on my dodge durango?
where is the camshaft sensor located on my 07 dodge durango 5.7 hemi.
I hope this helps. This is what I could find for a 2001.
このアンサーは役に立ちましたか?
nice try but this is for a different engine. Ends up being on the wrong side of the motor @oldturkey03 oldturkey03 has the right answer
Luis Lopez, the Camshaft Position Sensor is located below the alternator on the timing chain case cover on the right front side of the engine.
このアンサーは役に立ちましたか?
you are wrong, alternator is on the drivers side. ac is on passenger side. the cam sensor is under the ac. on the passenger side under the head
Does the 4.7 have 2 cam sensors I replaced the right passenger side but was told it was bank 1 driver side but don’t seem to locate it any help or images would?
過去 24時間: 3
過去 7 日: 28
過去 30 日: 134
今までの合計 11,926
