メインコンテンツにスキップ
このBose Soundlink Mini II は、ワイヤレス、Bluetoothスピーカーです。コンパクトなデザインから、質の良い音が流れて来ます。重さはおよそ700g、Bluetoothは約9mまで届きます。2015年6月26日に発売されました。
20回答 すべてを表示
How to attach rubber pads at the bottom?
I took out the rubber pads at the bottom of the speakers to try out the charging cradle and I'm finding attaching it back hard.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
1 件の回答
Struggling with this as well - the rubber tongue won't go in... Any ideas?
このアンサーは役に立ちましたか?
スコア 0
2 件のコメント:
After a long struggle I finally just cut the tongue off. I then put the silicone foot pad back on the speaker and after months of using and moving it the pad hasn't come off. Get a pair of scissors, take a deep breath, and cut that thing off!
さんによる
Thanks for re-assuring!
Eventually after a similar struggle that's what I already did :) Looking at other instructions, it seems that one needs to remove the back grill and then use tweezers to catch the edge of the tongue to pull it in. Since the grill is held by a sticky tape, I think it will be quite challenging to fit it back in a way that it will look like new - in fact, none of the instructions show how the device looks after assembling.
So I well decided that the tongue is not that functional and indeed the rubber pad is held well with it's edge grooves.
さんによる
コメントを追加
回答を追加する
Francisco Santiago さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 5
過去 30 日: 21
今までの合計 2,591
