メインコンテンツにスキップ
The ZTE Lever is a black 4G LTE smart phone sold in Wal-Mart stores with no contract and unlimited data. It comes with a front and rear facing 8MP camera. It was released on December 31st of 2014.
11回答 すべてを表示
Is my battery faulty due to charging?
My phone currently is charging very slowly. I will turn the phone off while it charges for hours and it only charges maybe like an extra 10%. If I charge it while it's on, instead of charging up, it charges backwards if that makes sense. Also, it will only charge in a certain position. I've tried different chargers and even charged to different computers, and I still receive the same result .
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
If you have to position the charge cord in a certain position to get the phone to charge then the charge port likely has some pins that have broken in some area of the charge port. That could be why it charges with the cord in a certain position allowing the broken pins to make contact again which then results in the battery indicating charging. I would also assume with the pins being broken, even though they are making contact if held at a certain angle, would be the reason behind your slow charging issue due to resistance from the breaking point which is not allowing as much current through. I have repaired a ZTE Lever that was having the same type issues and it was broken pins in the charge port. So to fix it I had to replace the charge port which requires soldering as it is soldered to the motherboard. It may not hurt to check the battery too.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Azalea Buxton さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 4
今までの合計 349
