Is there a place to reset my tablet?
My tablet is frozen on a game an can not get it off it want even turn off? Need to know how to reset the tablet.
I FINALLY HAVE IT! No one has been able to figure out the hard reset on the trio stealth G5 7.85, BUT I DID! This works for forgotten pattern codes and everything! And its a screwed up way but here goes:
このアンサーは役に立ちましたか?
Awesome Worked 10/08/18
I hate to say it but this didn't work for me. I have tried the usual technique everyone says to use to hard reset my tablet but it doesn't work. I contacted Trio Tablets and they are even refusing to help me figure out how to do a reset. So frustrating....
thanks so much
Worked for me first time tablet been locked for 4 years thank you
Thanks so much. This is the way to enter recovery mode in that tablet.
Thank you.
Dear friend
i had read your question
you first need to remove back case then disconnect battery and connect it it will work fine
if you want reset (need battery percentage more than 50% to avoid software brick)
1. turn off device first
2. hold vol+ button and power button together
3. from that menu choose data wipe/factory reset option
4. select yes and wait till tablet getting restarted
its done
good luck my friend
if you need guide for the tablet follow on linkuser manual
このアンサーは役に立ちましたか?
i dont know what the password is for decrypt storage is
That you so much
1 power off tablet
2 hold volume down and power button together
3 keep them down until the trio logo comes up and flashes ( wait for the trio logo to blink )
4 release the power button while still holding the volume down button quickly press and hold the volume up button
5 it should go directly to the recovery screen and you can use your volume keys to navigate the recovery options
このアンサーは役に立ちましたか?
Still doesn't work for me.
All this method does is takes me to safe mode.
go into settings hit recovery mode it will restart and go into recovery moved volume down button to wippe cach then hit reboot
Can you fix my tablet trio 7.85 to let it charge again?
このアンサーは役に立ちましたか?
TCarpenter I want to Thank you I had tried all the other Hardrest and nothing worked just found your fix it tip. Got right to the factory rest and now restarting my Trio 7 and waiting for it to start back up. You are AWSOME THANK YOU so much I have the Welcome screen it's like I just took it out of the box. Thank you again
Press and hold the power button for 15 seconds that reboot the tablet
このアンサーは役に立ちましたか?
過去 24時間: 1
過去 7 日: 9
過去 30 日: 30
今までの合計 9,616
5 件のコメント
My tablet resets ever time I turn it of can anyone help me
Lunar Gamer さんによる
I tried all three answer none work. So what am I doing wrong ? Over and over and over I've tried.
maroon32 さんによる
I forgot the password to get into my tablet, how do I reset it?
Debbie. Falconer さんによる
Oh yea.. that green guy doest even show up
Hannah Hart さんによる
I tried every sequence there is to do a hard reboot nothing works
Bodhi Zaha さんによる
