メインコンテンツにスキップ
HPのOfficejetはインクジェット用プリンターのシリーズです。
Printer will not print I received an error message 0x610000f6
My printer is a HP Officejet 6700 Premium. I also received a message on my computer which said: scan to computer no longer activated
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 2
コメントを追加
1 件の回答
ベストアンサー
"scan to computer no longer activated" this is a network connection problem / unactivated on the PC app/softawere
in regards to your error
you can try the following '''In some cases, removing the ink cartridges and resetting the printer can clear the error message.
1.Turn on the printer.
2.Wait until the printer is idle and silent before you continue.
3.Disconnect the USB cable from the rear of the printer. If your printer has a network or wireless connection, leave it connected.
4.Remove the ink cartridges from the printer.
5. With the printer turned on, disconnect the power cord from outlet or power strip.
6.Wait for about one minutes and Plug the power back to the printer .
7.Turn on the printer, if it does not automatically turn on.
8.Wait until the warm-up and become silent.
9.Reinsert the ink cartridges, and then close the ink cartridge access door.
10.If you receive a prompt to print a calibration page, do so.
13.If you have disconnected the USB cable, reconnect it and Try to print.
GoodLuck with the
このアンサーは役に立ちましたか?
スコア 2
4 件のコメント:
I still get the same error message but I sure thank you for having me try this.
さんによる
then I suggest u open up the printer and looking for any broken parts especially at the print head resting station?
さんによる
I have tried the 13 steps as you recommend Abdul and the printer is now working again - Thank You!
さんによる
Thank you but did not work.
さんによる
コメントを追加
回答を追加する
Jean Nester さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 3
過去 30 日: 10
今までの合計 3,035
