メインコンテンツにスキップ
Nintendoのハンドヘルドデバイスは2011年2月に発売されました。モデル番号はCTR-001です。
455回答 すべてを表示
Top Screen has multiple issues.
Earlier my 3DS was involved in a rather unfortunate soda accident, and after cleaning it out and letting it dry for awhile it works relatively fine, but with a few issues
-Top screen is brighter than bottom and is unaffected by brightness changes in theme menu
-Top screen remains lit while in sleep mode while the bottom screen sleeps like it should
-Error message is given whenever I attempt to use exterior cameras
-3D mode had to be manually disabled via parental controls because the slider stopped functioning (remained lit despite my turning it completely down)
This is an original 3DS, not an XL.
Thank you in advance!
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
Even though you may have let the DS dry out, the issue still remains that there was liquid spilled causing issues with the circuits. Something internaly has been damaged by the fluid and will need to be replaced.
Good luck
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Voidyskelecat さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 1
過去 30 日: 2
今までの合計 101
