メインコンテンツにスキップ
1985年に任天堂株式会社から北米で発売されたゲームコンソールで、Nintendo Entertainment System、モデルNES-001と呼ばれるものです。
57回答 すべてを表示
NES only works without cartridge bay
I am having a bizarre issue with an NES I just bought and I am unsure of how to fix it. I was getting the black screen of death. I opened it up and deep cleaned everything in it including the 72 pin. Before I place the cartridge tray back in and over the pin connector, the NES will read and play just fine. When I put the cartridge tray back in and seat the game that way however, it returns to the black screen of death. It looks like it has been worked on before and the cartridge tray itself seems raised a little bit too high over the 72 pin connector. Does anyone know the solution to this? Do I replace the 72 pin or the cartridge tray?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
Something you might want to take a look at. You might want to crack open the case and see if there is a carriage adjustment screw on the side of the cartridge bay. Some of the systems that offered replacement parts would slightly modify the replacement parts because of patents.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Stephen Roberts さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 3
過去 30 日: 9
今までの合計 197
