No service - sim card is detected - Galaxy s6
Hi
Any idea to why my Samsung S6 wont pick up any signal. Where is the GSM antenna located? It picks up a sim card is inserted.
I have replaced the screen, it was wokring before this. Help!
It seems like a software issue try resetting the phone. (Remember to back up your data first)
この回答は役に立ちましたか?
I have same issue on my s6 i insert the sim and it detects the sim say i need to reboot after rebooting still i have no signal it says only
この回答は役に立ちましたか?
[image|1709845] [image|1709844] here my screen shot
Dear friend,
I had read your question,
first check ur phone is in offline mode/airplane mode? if in airplane mode switch to general mode!
otherwise check IMEI number first by dialing *#06# if it have and 16 digit its ok
you said emergence number is working (so its problem related to imei)
good luck my friend
この回答は役に立ちましたか?
My SIM is detected but but showing emergence calls only...what could be the problem and what the solution?
Hello friends
why 16 digits is OK?
During the registration phase of the mobile terminal on the network, the check digit (the 15th digit) is not transmitted, more precisely a "0" is placed. This means that it is the cellular network IMEI is always composed of 15 digits, but only the first 14 original stages to those of the original IMEI.
Regards Stefano
Hi even I'm having the problem Shows no service but the signal bar is full! What do I do? Very urgent
この回答は役に立ちましたか?
Maryam I'm currently having thesame problem with my phone. Can you help tell me how to resolve the issue? My phone is showing no sim card and yet the network bar is full.
backup your data and try a factory reset
I tried it but still not solve my issue. I checknthe sim slot and its totally fine no flulty pin. When i insert a sim it detects it say i nedd to reboot then aftee reboot still no signal my s6 is korean variet
この回答は役に立ちましたか?
My Samsung sm-g920v is not excepted my sim card…give me error no sim card…what can I
この回答は役に立ちましたか?
過去 24時間: 0
過去 7 日: 15
過去 30 日: 57
今までの合計 6,931
This also changes to Emergency Calls Only as well.. back to No service. Tried different sim cards.
matt mitchell さんによる
