Broke charging port inside the case..
I have a asus f553ma hh24tq laptop, need to replace the charging port..Is this something you can do ?
You mean the DC jack?
You can do this.
most of the time you can replace the DC jack.
Sometimes this is soldered to the PCB.
send us a picture so we can look.
Opening a laptop is not that hard..
Kind regards,
kevin
このアンサーは役に立ちましたか?
Same issue here. Have laptop open, need the dc jack. Soldered to the mobo. Not sure how post pic. Model is F553M. Laptop will come on but screen is blank, if you mess with power connector you can get the screen to come back on.
このアンサーは役に立ちましたか?
How... Did you manage that?
And to answer your question, look online and you should be able to find a replacement. It's a standard port, so with a bit of soldering, you should be able to swap it out.
I am not liable for any damages you do to your own devices. Attempt my fix at your own risk
このアンサーは役に立ちましたか?
過去 24時間: 1
過去 7 日: 6
過去 30 日: 15
今までの合計 627
