I need bios rescue password 2012-01-01
hi i need BIOS RESCUE PASSWORD for my asus m80ta
i test ABLDABLA and not work for me plz helpppp
ABLDABLA (NOTE: must be all Caps)
このアンサーは役に立ちましたか?
if AZERTY keyboard : it's QBLDQBLQ
Parfait fonctionne sur x552mj
Hi All
If you can find the older topics, you can find the solution, anyway reshare again
Try this method, turn on the computer and access BIOS
Please visit this link below.
https://pastebin.com/raw/L3c3rySj
Subtract current year and get the password
e.g.
2019 - 10 = 2009
2018 - 10 = 2008
2017 - 10 = 2007
.. etc
For example:
このアンサーは役に立ちましたか?
2007-01-01 ABLDABLA igot for 2012/01/01
このアンサーは役に立ちましたか?
2012-01-07 please
Code worked for Asus X551M 01/01/2012, thanks
Disconnect the cmos battery from your computer then re plug it, this will reset your bios.
このアンサーは役に立ちましたか?
Some of us don't have battery inside ;)
hi same problem with 2012/01/01,
anyone can help?
thanks
para los que aun no desbloquean aca esta el unlock x fecha https://www.biosbug.com
goathack vzla
このアンサーは役に立ちましたか?
No funcionoa, al menos en mi transformer T200TA no sirve el pasword generado con el dia 2012/01/08
過去 24時間: 0
過去 7 日: 2
過去 30 日: 14
今までの合計 7,922
12 件のコメント
hi i need BIOS RESCUE PASSWORD 2012/01/04
=== Updaten (19-10-17) ===
kadir さんによる
kadir さんによる
Didn't solve the problem
Ernesto Ibasco さんによる
Same problem here, ABL… Password for 2012-01-01 not working.
Any other solution?
Just want to come in bios so we can install new Windows, set boot to USB..
tibor.lipovec さんによる
No didn't fix it and I forgot the master password on Asus laptop
7件以上のコメントを表示
