My iPhone is not charging when the battery is completely drained
My iphone is not charging when the battery is completely drained and when I charge my battery externally then I can charge it with my iphone it drains quickly even with a new battery and new duck connector still the same thing
Update
My reception is ok and I replaced the battery and the USB connection with a new one still the same thing is there anything else that might cause this problem.
regards
この質問は役に立ちましたか?
4 件のコメント
The main problem is my iphone is not charging when my battery is completely drained. It’s OK for me if I charge it two or three times per day but when it’s off then that’s it I will not be able to charge.
Grain さんによる
If you've ruled out the obvious then you'll need to look at the motherboardfor anything shorting the circuits. I would really have thought it was a battery problem though
pollytintop さんによる
which iOS are you on? some have reported big drains on iOS 4, also if running apps in the background/enabled location services/push notices etc will drain.
my battery lasts about a day...my reception here is only GPRS and it takes all the energy, if I get 3G...wow, loads of battery
pollytintop さんによる
did you check the gold antenna prong on motherboard is in contact with bezel?
pollytintop さんによる
