メインコンテンツにスキップ
Lenovo製のデスクトップPCのリペアガイドとサポートです。
97回答 すべてを表示
no sound on ibm thinkcentre m52 8212-1yu
Hi! I just got one of base IBM ThinkCentre M52 computers (8212-1yU).
Thanks in advance for your time and help!
This computer has windows 7 (32-bit) and Intel Pentium 4 CPU 3.00 GHz.
Under Device Manager, I see the following entries under "Sound, video and game controllers":
• High definition audio device
When I go to Control Panel --> Sounds and Audio Devices, it says "No Audio Device"."speakers not plugged in" the default device is the digital audio which is working but no sound out of the inside speaker
the sound card is built in on the motherboard, I checked Lenovo support site
There is no sound on this PC, though there are outlets for mic and speakers. I tried hooking up my headset, but here is no sound.
Micrsoft's Mr. Fixit utility
Any help would be greatly appreciated!
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
2件の回答
In the device properties can you change the default device from digital to analog duplex ?
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Try right clicking on the spear icon next to the time and date. Select Play Back Devices and check the defaults. the speakers may not be enabled. You should see a sound bar indication sound. The other thing is to update the drive for the audio system through Device Manager, if it comes back and says the best driver is already installed, then delete the device and check remove driver and then do a scan for hardware changes, this should force a fresh driver to be loaded.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
revolt25012011 さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 5
過去 30 日: 12
今までの合計 1,015
