メインコンテンツにスキップ
Repair guides and support for the 5th generation Honda Accord coupe, sedan, and wagon.
87回答 すべてを表示
I have to mess with the gear shifter while starting it? Why
I couldn't start my car, after putting it on a battery charger it started. It didn't work with regular jumper cables and vehicle. So I bought a new battery, still didn't start, I mess with the gear $@$* pushing it forward ( it is an automatic ) and holding it their while I try starting it, and it works. But why, why is it doing it how can I fix it and what caused it?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 2
コメントを追加
2件の回答
最も参考になった回答
Will the car start in neutral? If it does then @oldturkey03 is probably right but you may also want to check the shift lock as this can also cause problems when starting
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
@marshajo13 when you say pushing it forward, do you mean further into the "P" position? It does sound like a bad or misaligned neutral switch, You'll have to check it out. The switch is located in the central console. It is number 2 in the drawing.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
Marsha Sanchez さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 11
今までの合計 462
