メインコンテンツにスキップ
Repair and support for the 2015 version of the Google-produced laptop line, the Chromebook Pixel. This newer version improves the processing power, battery life and add new features to the 2013 model.
14回答 すべてを表示
How can I reset a 'managed by' chromebook pixel?
Hi guys! I recently bougth a used chromebook pixel on eBay. Unfortunately, it is 'managed by ...' and I have no idea about how to reset it.
Is it possible?
Thank you so much and sorry for my bad english :)
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 4
3 件のコメント:
Contact organisation that it is managed by and ask them to clear it for you, shouldn't be any problems if they've sold or given it away.
さんによる
Thank you for your answer but I haven't been able to do that! The organization seems to do not exist, I looked for it on google but there was not any good result. The seller does not answer and I did not pay with paypal, so my chromebook is such a beautiful 400€ ornament.
さんによる
@Luca Manna - Were you able to get to get this sorted? Is the Chromebook working now?
さんによる
コメントを追加
4件の回答
I seem to have accidentally deleted my first answer :(. You could try following this guide to "power-wash" your device externally to the logon screen. I am assuming that you are using the device for personal reasons and will not need to "enrol" your device in to another organisation.
Regards
Alex
このアンサーは役に立ちましたか?
スコア 0
4 件のコメント:
Yeah, just for personal use; I'll try tonight! Thank you so much!!
Regards
Stefano
さんによる
Forced enrollment is what I am facing too, I discovered who the organization is and called them, just to see how they respond. Oh, you most likely have a virus on your windows machine... (me)It is a chromebook... (them) Just reboot it and log in again. (me) this laptop was sold from your organization and needs to be wiped, it has corporate data on it.... (them) Just insert a Windows 10 boot disk and it will work... (me) <click>
You are faced by a "forced enrollment" which indeed makes the unit no longer usable, or is it.... Two ways to go about this, on the laptop is a VPD (read up on RMA Shim) or TPM that contains a serial number tied to a tag on the machine.
Using an Eeprom socket reader (look like a big clothing pin) that can read the 8 pins on the chip. Extract into an EeProm reader program through a USB dongle like this: https://www.amazon.ca/gp/product/B01JIND...
Write a new serial number.
OR replace the motherboard, ebay is selling them.
さんによる
So I did actually purchase two laptops that were enrolled and I have confirmed both to be perfectly working now without enrollment, I can power wash them, go into developer mode and do whatever I want with them. The steps are quite easy but it does require you open the laptop and have the EeProm programmer with the socket reader. Remove the battery make sure system is shut down (no power connector) Connect the socket reader, download the eeprom from the locked device, modify serial number and set enrollment = 1 to enrollment = 0, plus change the admin_forced = 1 to admin_forced = 0 - this can be done using a hex editor. Make sure to make a copy of the original file!! Now erase the eeprom using the programmer software, push the modified eeprom onto the machine. Either close up the machine or insert power and start with recovery USB and make sure you start the system with esc+refresh+power to get the yellow ! and system now automatically updates from USB. After this you are good to go
さんによる
@Al van der Laan and how di i do this??
さんによる
コメントを追加
do ctrl shift alt r to wipe it
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
I recommend trying to contact the organization that manages it to untie it for you. If the organization isn’t strict you should be able to wipe it but other than that it’s pretty much impossible.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
You typically can’t just power-wash managed Chromebooks, and reinstalling Chrome OS won’t work as the Chromebook won’t let you sign in to it, kind of like Apple’s Activation Lock. There’s a similar question How can I reset a managed chrome book back to factory, but it requires opening the Chromebook, entering developer mode, and changing the serial number
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Stefano Foti さん、ありがとうございました!
統計データ:
過去 24時間: 3
過去 7 日: 10
過去 30 日: 17
今までの合計 2,551
