メインコンテンツにスキップ
モデル番号A1312 / Mid 2010 / 3.2 GHz Core i3もしくは2.8 & 3.6 GHz Core i5もしくは2.93 GHz Core i7, ID iMac11,3
382回答 すべてを表示
Broken LCD temp sensor connector on logic board
I own mid-2010 27” iMac
While attempting to do the HDD swap, I broke the LCD temp port that's attached to the logic board, and now the cable doesn't connect properly. As a result, the fan is going maximum. The sensor cable is fine, it's that port on the logic board that's broken.
What's the part number for this part and what would be the best way to fix this?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
2 件のコメント:
Please post picture of damaged area.
さんによる
I will later tonight, but the connector on the logic board is broken, I accidentally pulled it while I was trying to remove the lcd panel. I think the cable is fine, but the connector is broken and the pin won't sit properly.
さんによる
コメントを追加
2件の回答
You might try just soldering the wires directly back onto the board. That should make things work again simply.
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
Yes, I'm gonna try that but I need to buy the replacement part because mine is broken.
さんによる
コメントを追加
@jiwoongyou I am certain you have this fixed by now. Answering this just for completion sake. That particular connector is a Molex 53261-8602.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Ji Woong You さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 5
今までの合計 3,552
