Sony DSC-TX9 Error E:61:10?
Error E61:10 blinking on camera. Unable to focus. Zoom doesn't work either. Ideas?
Error code E:61:00 mens your camera lens sensor problem
Turn the camera off
· Hold the camera face down over a hard surface (Like you are going to take of your desk) with only about half an inch above the surface.
OR reference the video files below for an alternate method.
· Turn the camera on
· Let the lens extend into the hard surface, don’t let it extend all the way. Mine retracted slightly and then tried to extend again (let it extend the second time).
· Lift the camera away from the hard surface and notice that the error message is gone.
· Take pictures of your favorite things.
NEW
Here is a video of the normal power up sequence of the camera.
Here is the first alternate method
Here is the second alternate method
Another fix is on youtube.
このアンサーは役に立ちましたか?
Geweldig! Het werkt super .
Dacht inderdaad dat ik mijn videocamara kon weggooien. Maar met iets simpels ( als je het weet
過去 24時間: 1
過去 7 日: 7
過去 30 日: 29
今までの合計 10,759
1件のコメント
Thanks. But unfortunately the autofocus seems to be completely screwed up. Tried absolutely everything, including your suggestion, but to no avail.
Andrew Bishop さんによる
