replace a a1212 with an A1261
hello, I have a macbook pro with the logic board a1212 broken , I would like to know if i can replace it with a A1261 (to have such a powerful pc).
thanks
この質問は役に立ちましたか?
thanks
この質問は役に立ちましたか?
No sorry they are not cross compatible , for starters the screens are different a1212 uses CFL bulb , while the a1261 uses LED bulb.
このアンサーは役に立ちましたか?
thank you, and whit a1229?
or any more powerful?
A white screen usually indicates a failed hard dive. Try disconnecting the drive from the logic board and booting from the original system installation optical disk.
このアンサーは役に立ちましたか?
you are right, thanks a lot!!!
Then you accepted the wrong answer ;-)
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 140
4 件のコメント
or another more powerful, as the model a1229
davidegatt さんによる
Why do you think the logic board is broken?
mayer さんによる
the screen remains white after power, and did not work any recovery procedure (pram reset etc.)
davidegatt さんによる
davidegatt さんによる
