メインコンテンツにスキップ
iPhoneの5代目となるiPhone 4S。このデバイスの修理は比較的簡単で、スクリュードライバー、開口ツールと忍耐が必要です。GSM/CDMA / 16, 32, 64 GB / 白と黒
2193回答 すべてを表示
after replacing battery, will not charge,turns on only when connected
After replacing the battery the phone only comes on when connected to wall charger. Battery % at 48% does not change and lightning bolt is on.As soon as taken off the wall charger the phone turns off. Will not charge with usb cable on computer.Can not make or receive calls,no sound.Did Try holding the power and home button until apple logo but no change.Does this sound like the dock connecter/charging port needs to be replaced or could I have done something else wrong when replacing battery?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
2件の回答
最も参考になった回答
It sounds like the battery connector to me. Here is a good video about a similar problem. I'm not sure about the battery percentage though.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
There is a chance you could have damaged a charging IC when disconnecting the old battery. Its also possible that a charging IC was bad, which led you to believe your battery was bad. I'd bet money on one of the charging IC's being at fault.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
mike さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 90
