メインコンテンツにスキップ
The Samsung Galaxy A5 (2016), an Android Smartphones released by Samsung Electronics in 2016.
58回答 すべてを表示
Samsung Galaxy A5 2016 usb connection won't show up
Hello there
I just bought my new, Samsung Galaxy A5 2016
Everything is fine but the USB connection is not showing up in the notification menu
I installed the driver, Samsung KIES and i updated all the USB drivers, but it still just charging when i connect it to the laptop, i tried another USB cable and it's the same charging and no MTP, i tried another phone and everything is fine there is data transfer but my phone NO!
Any help PLEASE ?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 11
13 件のコメント
I have the same problem. Help please!
さんによる
I have same problem. a5 2016
さんによる
i have same problem man... yestarday suddenly my issues are all USB problems .... i have used 2 month ..
1. No Fast Charging ( Was there before )
2. No OTG support ( Was there )
3. I can't connect the phone to my PC. Nothing happens when i connect my phone to PC. The phone just
charges when i connect it to PC. Nothing comes in the notification window of my phone when i connect.
pls help me how to sloved this problem
さんによる
I have the same problem but on a A5 2017
さんによる
https://www.youtube.com/watch?v=8XxEByzD... this might work for you
I have changed charging port with a new one. Still nothing
さんによる
8件以上のコメントを表示
コメントを追加
16件の回答
最も参考になった回答
Hello mate, i just came across this problem too. I communicated with samsung support and they were nothing but dramatic. They tried to help me by advising me to switch my device off and on and things like this... I googled the problem for answers and I came to the conclusion that is a broken USB port.
My problem is only when i try to connect the phone to copy data. There is NO problem when i charge the phone.
My solution is to repair the phone. I ordered the replacement part of eBay and i will fix it myself. I will post an update to tell you if it was a success or not!
PS
If you want a "How-To" of the repair procedure please let me know!
このアンサーは役に立ちましたか?
スコア 3
3 件のコメント:
Yes, please share if you fixed the problem. Samsung support is bad as !&&*. I've tried all the possible solutions without success. It really seams to e a defect. Thanks
さんによる
Not all cell phone cables transfer data. Some only charge your cell phone, particularly the older ones. Before you make changes to your phone or your computer, buy a new cable that is labeled, FOR DATA TRANSFER. Good luck.
さんによる
@Stratos Kordonis , I think I have the same problem...my phone is not being recognised by any computer however they are able to recognise other USB inputs...were you able to fix it?
さんによる
コメントを追加
Hello ladies and gents,
Hopefully by now you have solved the problem. I received this issue when I first connection my phone into one of my four usb ports on my computer. I would open the phone's folder system and see nothing. I just tried a different usb port, and this time I touched/opened my phone while it was plugged in. It asks me if I want to establish a MTP connection, and I show yes. KERSHAZAM! The phone's data connection is now set, and I can transfer video and audio.
Cheers!
Jeffrey
このアンサーは役に立ちましたか?
スコア 3
2 件のコメント:
it worked! Thank you
さんによる
Doesn't work. Just continues to barely "load" or sometimes says the folder is empty.
さんによる
コメントを追加
TRY THIS.. IT WORKS FOR ME
http://www.orangenarwhals.com/2015/09/no...
このアンサーは役に立ちましたか?
スコア 2
3 件のコメント:
you made my day
さんによる
This does not work for me either. Seems no way of saving this setting. If you go out of the USB page setting is lost despite a saved! Message coming up. Cannot get laptop to see mtp or mass storage or anything else.. Used to just plug phone in & it just used to work. Must be Samsung operating system upgrades. Trying to make us all store everything on cloud..
さんによる
Exactly, I suspect Samsung has altered the design of the Type c output. To forego AV transfer. Bad move, sometimes you need the 100% reliability of a direct connection. Still can't get confirmation from Samsung, conclusion after trying cable, adapter, converter there is no bloody AV. Peter
さんによる
コメントを追加
I recently had the same problem. I eventually discovered that the usb lead will fit into the A5 either way round, but will only transmit data one way round. So they seem to have used a phone lead that does not appear to be handed, but actually is handed. Where is the sense in that?
このアンサーは役に立ちましたか?
スコア 2
1件のコメント:
Thanks Bob, your suggestion just worked for me, just pushed the usb lead into the mobile a bit harder then in it went & presto !!!
さんによる
コメントを追加
There is a video that shows how to do it:
https://www.youtube.com/watch?v=rQQTVr29...
I did all that and it still didn't work so I dug out the original white charging cable that came with the phone and connected that. When it still didn't recognize the phone I rebooted while the cable was connected and voila! it worked. I was still had it set on MTP connection though not PTP.
このアンサーは役に立ちましたか?
スコア 1
4 件のコメント:
I had bought a Genuine cable from Samsung and when I used that it worked. THANKS SO MUCH.
さんによる
Thank you Farmgirl.
さんによる
I didnt even have to reboot the phone !!!
さんによる
Earlier in this process I had upgraded Samsung Kies which upgraded USB drivers but I suspect these were for the PC not the phone Im not sure this had anything to do with it? Hmmm
さんによる
コメントを追加
Hallo
I think you have to turn on USB debugging .
http://www.techoxygen.com/enable-develop...
Jan Helm
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
I tried that and turned on the USB debugging, but I still can't find "USB for". What do I do now?
さんによる
コメントを追加
Hi - if you look into your notifications from Android - there will be one about how the connection is made to the phone. I changed the option of transfer via USB from an MTP connection to a PTP connection, and my phone instantly appeared as an option in my directory and the usual screen message popped onto screen. So seems it is an android options issue.
このアンサーは役に立ちましたか?
スコア 0
2 件のコメント:
How did you change that option? Where and how?
Thanks.
さんによる
dial *#0808#
さんによる
コメントを追加
Thanks Bob very helpful to know. I have had this problem multiple times thinking it had to do with Win 10 updates wasting a lot of my time - the call centre and web chat help was fairly useless - I finally got this resolved by taking it into a samsung service centre for the people there to look at...in the end both the data cable and the original cable appeared to be damaged in some way...I was told if the data pin is damaged which it can easily be so after 6 months then the phone will charge but not transmit data. anyway I now have a new samsung cable. On the older models as well you select MTP+ADB which you can access via dialling *#0808 I think to make sure it gets read as a storage device.
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
Worked for me after rebooting the phone
さんによる
コメントを追加
I have the same problem (No fast charging and my phone not showing up at my PC when it was plugged in) until I went out and bought a new charger cable and that fixed the problem for me.
PS: I tested with my friends charger to check if it was my phone or the charger.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Most of the time its not something simple.My galaxy a5 2017 had a similar problem at 4 months ,the usb tethering stopped working as well as the fast charging. It turned out to be the motherboard/main board and it had to be replaced(the motherboard that is).Mine was fixed under warranty by Samsung and they were very good it only took one day to fix.Try the simple stuff first .Otherwise in for repair hopefully covered by the warranty.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
I couldn't get it to work so i just emailed myself the pictures from the phone and then saved them to the computer.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Just tried connecting the phone using the cable from my IPlayer instead and bingo the Galaxy J5 appeared on the File Explorer on my Android Dell PC. No need to download any drivers or software.
My photo files are situated in the following folder:
ThisPC> Galaxy J5 > Phone > DCIM > Camera
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Sir
Immediately after connection accept the popular in mobile
Then turn on the hotspot
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
Pop up accept
さんによる
コメントを追加
Not sure if anyone is still having this issue, I just discovered a function in Windows 10 system settings called Your Phone which allows data sharing through either wifi or mobile data, no cable needed. You do need to also install an app on your phone and a Microsoft account in this case. Not sure how and if this also works with other PC OS
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
I connect my tablet with cables as instructed but tablet to tv does not
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
Howard Mattacott make and model of the tablet? Has it ever worked before? Make and model of the TV might help as well.
さんによる
コメントを追加
I have same problem in my phone.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Aly さん、ありがとうございました!
統計データ:
過去 24時間: 4
過去 7 日: 19
過去 30 日: 77
今までの合計 82,298
