メインコンテンツにスキップ
2012年9月12日に発表されたApple社による6番目となる iPhone。このデバイスの修理方法は前モデルと類似しており、スクリュードライバーと開封工具が必要です。GSMかCDMA方式、16/32/64 GB。 本体色は黒と白。
2522回答 すべてを表示
Did corrosion form after I successfully used a bag of rice?
My iPhone 5 got stuck in my bed sheets and .went right in the washing machine..!
I used a bag of rice and after 24 hours, the phone was recognised by iTunes. But the day after, it stopped being recognised.
Does the fact that it was recognised at first mean that the phone is still recoverable?
Is that corrosion that formed on the motherboard?
I removed the EMI shield and use Isopropanol 99.9% with a toothbrush but it didn't help.
How am I supposed to get rid of corrosion?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
Unfortunately, sometimes it is irreversible and it sounds like you have done pretty much as much as you can. Some say rice shouldn't be used as it can deposit more minerals than just water itself (starch etc.) which can contribute further to corrosion.
Personally with a water damaged device I would tear it down as much as possible and use a combination of Isopropanol 99.9%, time (to dry naturally) and patience, remembering to avoid putting power through any part of the device until you can be fairly certain no moisture remains.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Alex222 さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 3
過去 30 日: 3
今までの合計 116
