water will not dispense even though it has been descaled properly
machine works properly one day, making two or three cups and then does not work for weeks. Has been descaled properly several times back to back
you have a defective solenoid,there are two of them .
to test apply 12v to each one
このアンサーは役に立ちましたか?
Can the solenoid so be replaced?
Solenoids were not the problem. They work, machine still does not.
There is a air pump and a water pump. Apply 12v dc to test if they test ok then you have a problem in one of the spring valves
what is 12v dc??
過去 24時間: 0
過去 7 日: 4
過去 30 日: 7
今までの合計 665
