Why all the squealing
When I first turn it on it squeal loudly then stops, but sometimes will squeal again while driving. Why does it do this?
@grandmair1996 sounds like a slipping belt or worn belt tensioner. I'd suggest you replace the belt and while you do so check the belt tensioner for excessive slop/wear. Replace that if needed. If you can tell us what engine size your Honda is, we can give you more specific information
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 1
過去 30 日: 4
今までの合計 110
